Repair/Replace/Sister 30 X 30cm Oak beam in French barn.
26 Jun 2026
France
Hello all. I hope to get your thoughts on my problem.
First, the situation is I am on the last (of 9 beams) 30 X 30cm Oak beam repair or replacement, or sistering with Oak joists.
Of the 9, I have replaced 3, and repaired and sistered another. The remaining 5 have been OK.
So I am not phased by this stage of the project.
To allow you to get an overview of the problem, here is the overview. I have reduce it to like a Thumbnail size, but you can easily expand it again, I think.
The beam in question is the one on the right. It is supported along its length by the 100mm block wall, except for the doorway.
To the left the joist are all in and boarded, but the boards are not nailed down yet. I will nail them down when they have acclimatised. So the 3X2 across the hallway is purely to establish the level across the hallway, for upstairs. Although I was intending on creating a bridge over the hallway, at the far end of this photo. The room on the right will then be a bedroom, the room on the left will be a separate WC and a bathroom. There are two more bedrooms to the left.
That infilled doorway on the ground floor will become the main entrance.
The problem beam. Here is a few photos of close up the rotten far end of the beam. It has now been cleared of rotten wood and treated.
A wider view
And the other side:
And a wider view
I know there will be difficulties with repairing this with epoxy grout and rebar because I can see a hole right through, bottom to top
The other end of the beam is sound, again the 3X2 is just ascertain a level from the floor the other side of the hallway.
i seem to be having some difficulties with posting. I'll post this bit and then add another post.
So here is the view of the top of the problem beam
And a wider view
As I see it I have three choices:
1. Replace the beam entirely. The problem with that, and which I never had with the other three replacements, is that this one has the bottom of the crook frame attached to the beam ends, and there is a wall underneath the beam.
i am not phased with creating a mortise in the beam for the tenon at the bottom of the crook frame to sit in. although it would cause problems. It is more the wall underneath that creates the problem. Previously I have raised the new beam on a scaffold outside and a scaffold inside, and pulled the new beam through the wall and into place.
Now the wall would create difficulty in manoeuvering the beam (at about ½ ton maybe) along the top of the wall, or alongside and then sideways.
The tenon could be cut properly on the one end, and a one-sided tenon on the other end, with the cut-off piece replaced after the beam is in place. But the wall prevents any vertical movement.
I would have to remove at least the top course of blocks, maybe more.
Choice number 2.
I could splice a new piece into the worst affected part, about 3.3 metres, with a lapped joint each end of the splice.
Something like this, viewed from the top. I have some 10mm threaded bar in stainless steel.
And some some repair with epoxy grout and rebar. I am not phased by this. I have done it before. But this beam is in worse condition, and I am concerned about leakage of epoxy resin. There will be a lot of silicon caulking or hot glue gun and bits of wood required.
Choice number 3
Sister each side with Oak joists.
Again I have done this before, with the beam that I repaired with epoxy resin and rebar. That one was not supported except between walls.
Then I placed the first, lowest joist in situ, added a second one above it, and then a third one above that to get the right height for the floor.
Only the lower two were in pockets in the wall, not the top joist. that just sits on the other. This side will be visible, and there is a difference in the floor heights either side due to existing beams, hence the short length of threaded rod visible this side.
As shown here
The other side. You can just see the original beam peeping below the new Oak joists.
The length between the hall walls is 5.75 Metres.
Annoyingly I have 2 off 5.6 Metres in Douglas Fir. sitting in the other barn and another 5.8 Metre piece, all 210 mm X 70mm.
Other bits of information, i will be placing joists between the rotten beam and the beam to the left of it in the first picture. Whether those beams sit on a joist between the walls along the rotten beam, or sit in joist hangars fixed to a sistered joist doesn't matter.
Then there will be more joists for the floor of the room on the right, these will over shoot the new beam to the right of the rotten beam and either sit on a stone ledge, or in hangars on a leger board, fixed with bolts and epoxy to the end wall.
Surprisingly, the total replacement of the beam is probably the cheapest option, but the most difficult work, manly due to the weight of the beam. 30cm X 30cm X 6 Metres of green Oak, maybe about ½ ton, and the scaffold inside and out.
Any epoxy grouting will probably be the most expensive, at a minimum of £500 worth of epoxy resin + loads of hot glue gun, silicon caulking and maybe epoxy resin putty.
And a wider view
Choice number 2.
Choice number 3
As shown here
Steel flitch plate it either side. Ugly but workable.
I can't quite work out the function of the beam - is it to prevent spreading?
Thanks for your interest Stephen.
Yes. It's original function was to prevent the crook frames spreading, and to carry the load of the upstairs floor, which was more of a barn loft for storing straw and maybe animal feed. The block wall below it would not have been there.
There was originally a timber wall, comprising old bits of timber, which was insufficient to carry any load.
I built the block wall, on a foundation with a dpc and wall ties to the original barn stonewalls.
So the only real function now is to stop the feet of the crook frames spreading.
Any load it will carry now for the upstair floor is transmitted to the block wall.
But, the beam is so badly affected, it is beyond a patina description and will look a cobbled-up mess on completion
Any attempt at repairing it may probably be wasted epoxy resin on the floor, and the epoxy resin is not cheap, plus the stainless threaded rod, (OK, I already have those), and the cost of Oak joists either side of the original beam to provide a workable support for the first floor joists.
By the time I've bought and installed some Oak joists positioned either side of the beam, I think I might as well replace the beam.
So that's the route I am seriously considering now.
It will be the cheapest option and provide the best aesthetic and functional finish. A new beam is probably about €400, a bag or two of lime and some sand to make good around the beam in the outside walls, and a few blocks to rebuild the top courses of the wall is really the only materials needed.
The process will be much the same as the previous beam replacement: scaffold outside and inside to slide the new beam in place, only lower than its intended finished position.
I can maybe use the block wall incorporated into the internal scaffold. it will have a flat top to it.
When nearing the finished horizontal position I can cut the mortises in the beam to house the tenons on the bottom of the crook frame feet.
Lift the beam up and into its finished position, and basically make good.
It does mean removing 1 or 2 courses of blocks from that internal wall, and knocking through holes sufficient to pull the new beam through the outside walls.
I can use a heavy duty ratchet strap to temporarily prevent any spread of the crook frame.
I could even make the beam's finished position higher than the current beam's position, and repeat the raising on the other new beam already installed.
This should give the finished job a better aesthetic look.
If I get my measurements and sums right the upstairs floor joists will sit directly on the new beams, and no packing or infill pieces will be required.
They probably travel outdoors and tie those trusses?
Yes, the feet are built into the wall.
When I replaced the crook frame, the one outside wall comprising blocks was reduced to the beam height already.
And the other side I had to remove a fair bit of stone to expose the bottom of the crook frame.
Yes, good suggestion which I had not considered. As you say, ugly but workable. It think it will create a problem of providing a workable support for the floor joists.
Creating the 'elbow' in the replaced crook frames required flitch plates. The originals were created by natural bent timber selected for the purpose.
The local wood mills probably thought I was a nutter asking to buy Oak timber with a bend in the middle, and of course modern machinery cannot cope with such cuts.
So I created the bend with flitch plates, well protected steel and stainless bolts. You can see one side in Picture 7 in my first post.
