Repair joint expansion caused by sinking pavement
7 Mar 2020
Hi, I have just discovered this crack caused by a sinking path in the hot weather. It's in the angle between my house wall and the garden path. Would the best repair for this be something like a silkaflex ebt+ sealant and backer rod? The gap looks about 6mm wide and maybe 10mm deep.
I don't know the answer.
Why do you think it will be a problem though?
If the DPC is higher, I don't see what the problem is.
Caveat alert- not my area of knowledge though.
Best of luck.
Thanks - it may well not be a problem, but I wanted to avoid water seeping in in the winter - The wall/extension is at least 30 years old and pre-dates us, so I don't know what sort of DPC there is in place
Perhaps if the gutter downpipe actually went into the gulley, instead of running over the paving and seeping down the cracks, you might stand a chance?
Thanks. There is actually two holes in that drain cover and the pipe is going into one of them. But I take your point
