Dragging that from another thread flowed nicely into my today little just job and the reason my post on '6 core flex' was delayed by several hours:I have a reasonable degree of knowledge, 'skill' and,dare I say, 'competence' across what is probably a fairly unusually wide range of disciplines. However, I have only been formally 'trained, qualified and experienced' in a relatively small proportion of those disciplines, many of them having been 'self taught', usually by reading and doing things like 'looking at diagrams' (or, theses days, I suppose also videos!).
Conversely, I'm sure we've all seen examples of people who have been formally trained and qualified, with lots of 'experience' (often experience of doing this badly or incorrectly!) who are not really 'competent', or necessarily even safe, in what they do!
I was out on a light switch replacement this afternoon.
One which was replaced yesterday (Sunday) by an insurance service. We were sent in today by the insurance company to sort it out as it was reported as 'keeps tripping the fuse'.
The broken switch was in the rubbish bin, 4 gang 2 way with 'Loop terminals - very handy to have the instant comparison/explanation with the replacement! the faceplate is basically broken in 2 with a chunk of it between 2 switches missing and bits of exposed brass.
Replacement switch 4 gang modular (I assume from SF as very close by) fitted with intermediates
Also in the bin was last years TV license with this on the back... even handier!!
I assume it shows the 'before connexions' and the replacement had been wired exactly the same although the ladies told me he spent ages trying different combinations.
I've marked the terminals with a blue circle which had been 'LOOP' terminals but now the intermediate switch L1' lines
I've marked the terminals with a black square which were permanent neutral
I've marked the terminals with a red square which are permanent line
Switches 4 & 1 running on one lighting circuit but short L to N when switched off there seems to be 2 'loop ins' and 1 'loop out' the neutrals are linked (and have to be for the remainder of the circuit) but the lines are not linked
Switches 3 & 2 are on second lighting circuit
Switch 3 is switching neutral (cable #10 is feed to SW3 L2 and SW2 L2' [used as COM]) - Cable #6 T&E to the light has red, blue and green/yellow insulated cores and yes it really does appear to have those colours.
Switch 2 the SL (returned from distant switch via strapper) is in the switch's 4th terminal but doesn't affect operation
It didn't take long to diagnose why SW 1&4 tripped the RCBO and that was even without tripping it myself, it might have even taken longer to drink the COT than fix the errors. Apparently the insurance guy was there for several hours.
