Dealing with embossed paper on lath and plaster ceiling
25 Nov 2006
London
Hello
My landing/staircase ceiling is covered with embossed wallpaper (the bubbly stuff) which is also above a picture rail. It’s also got coving.
I’ve managed to removed the paper above the picture rail but the coving has obviously been added after the paper went up as I needed to carefully score it with a Stanley knife. The wall is not too bad, it’s had a few cracks that have already been filled so I plan smooth, Gardz and then put a plain lining paper on.
It’s a 1930s house and the wall is lath and plaster so I assume the ceiling is too.
The embossed paper came off relatively easily but I’m worried about opening a can of worms if the ceiling is in bad condition, especially as it’s a tall ceiling. It’s about 12 sq m and once I start there’ll be no going back.
It’s tempting to leave alone but the rest of the house has smooth walls and this area looks dated.
Anyone had any experience of this and/or advice on the best approach? Thanks
How old is the property? (edit- sorry you said 30's). I recall painting cabinets in Bedford Park (Chiswick). The property was 1830-1850. In conversation the owner told me that the ceilings were reaching end of life. Some fell down of their own accord. He overboarded and skimmed each of them.
If you are careful, you should be able to remove the embossed paper, but, you will probably find that it was used to hide cracks. If you are happy to feather out the cracks- go for it. You may need to use lining paper after. BTW Lining a ceiling on your own is relatively easy. As you concertina the paper on the pasting table, you can put tight creases in the folds (every 12" or so). The creases will disappear once the paper dries. A trestle and boards makes life much easier though. I have done it using a step ladder alone, was a bit of a chore. I used a wide filling knife (approx 16") to support the paper as I gingerly moved the step ladder.
Personally, I would be inclined to deal with the ceiling... but I am a decorator.
Thanks for the encouragement, I was beginning to talk myself into leaving the bubbly paper on!
It would be the path of least resistance but, yeah, I personally would remove it.
When you do so, take photos and we can advise you further.
Regards.
This is it beforehand. It’s only me that hates it and I wonder if I’m making a rod for my own back!
