Fluid master flush valve removal problem.
3 Mar 2005
Surrey
Hi, I went to replace the flush valve in our toilet, it's a Fluid master with cable operation in a concealed cistern. I cannot remove the top bayonet section because the cable inlet is jamming against the overflow tube. Will is go past the overflow tube if I force it a bit or can I remove the cable connector from the valve? Or can I rotate the bayonet the other way ?
Thanks. Dal
Take the cistern off and unscrew?
Maybe that's how it was assembled hence your problem?
Some quarter turn to replace. You can't do that.
There is a big nut under the remove. That's what you need to turn.
So you think cistern won't come off
I'd un build it in then.
One of the most stupid inventions ever. .I could not put up with that having had to remove a section of bedroom wall and in one case remove part of a ground floor ceiling to gain access to this built in stuff.
Jmo. Frustrated tradesmen. Still I charged them for it. Ha.
