Fluid master flush valve removal problem.
3 Mar 2005
Surrey
Hi, I went to replace the flush valve in our toilet, it's a Fluid master with cable operation in a concealed cistern. I cannot remove the top bayonet section because the cable inlet is jamming against the overflow tube. Will is go past the overflow tube if I force it a bit or can I remove the cable connector from the valve? Or can I rotate the bayonet the other way ?
Thanks. Dal
