Yes, but moved from the outside of the engine where they were fairly easy to change to inside the engine where they cost more than £1000 and take an experienced garage all day to change. If they snap it's goodbye engine.Are these wet belts what I have always known as camshaft belts
Yes so you have no choice but to adhere to the change times because if you dont and it go's there is no come back.Yes, but moved from the outside of the engine where they were fairly easy to change to inside the engine where they cost more than £1000 and take an experienced garage all day to change. If they snap it's goodbye engine.
Shafted more like.piston rings which after just 40k miles start to burn oil -- that's right eco piston rings burning oil.
Feel scammed yet.
Hi B,Have you considered the Toyota ProAce?
Essentially Citroen but I find they are better built than usual, and the Adblue problems seem to have been sorted.
Diesel 1.5 or 2.2 or electric.
Up to 10 years warranty, if serviced by Toyota.
Avoid auto if possible.
Ford's wet belt is a truly dreadful engineering nightmare - I wouldn't go near personally. A mate has a large Transit, it's covered over 100k miles, can't be worth much but he'll have to spend well over a grand or wait till it goes pop. Criminal!
John![]()
Should have asked him why they no longer fit wet belts to engines (apart from the oil pump drive belt).I went into Ford a while ago, when I had just heard of wet belts, and the salesman said he gets people coming in here, who have looked at the internet, and got the wrong impression of wet belts. He had no patience with me.
