Hi, any recommendations on best make and type to replace this old seized, leaking stopcock? I don't want to scrimp.
I'd prefer quarter turn unless advised otherwise. Would also prefer to go plastic pipe after the tap but again happy to take advice.
Also just trying to understand how the lower compression fitting section is fitted to that upper larger nut, will there be a stub screwed in to that larger upper nut which will need replacing as well to give a clean stub to fit back on to?
TIA
TIA
