Pulled hep2o insert out of pipe when demounting and reinserted
It has its uses but I don't like the idea of hidden pushfits or compression... It's advised against maybe even not permitted! Can't remember.
Gas has to be soldered if inaccessible.
It is advised against using inaccessible plastic fittings. Hep2o and frankly all plastic pipe suppliers would be out of business otherwise. Natural gas is always soldered copper and yes fittings must be accessible
Then again I see all sorts of abominations so doesn't really matter a fook what is or isn't permitted...
But it does when I do it.
I wish I had used copper BUT because the property uses 1.2mx2.4m chipboard flooring and the joists are not directly below partition walls which makes cutting large sections of board difficult. If standard floorboards were used I could have used copper. The floor layout would mean HUGE chunks of floor missing in all bedrooms for weeks for copper whereas plastic only needs small squares cut out.
Most properties are now caberdeck or some such.
I've had them up and back down again and used copper... To replace the plastic that the place(s) was/were built with.
Called out to a leak from the ceing to the hall below, who is to blame, the plastic fitting or the plumber?
Andy
Coz at the end of the day it's not really a safety issue but no fun for the homeowner if a fitting fails... Which they do! I'm seeing more and more o rings that have just disintegrated to black mush and bits.
Well once I've finished enlarging, repositioning and rehanging the rads to timber (as opposed to plasterboard as they are now) and redone all the rad tails and redone and few inserts, then I need to consider. If I put another magnetic filter on the bathroom rads and leak sealer in the pipework (which should seal pinhole leaks) the chances of leaks from that point onward are small. Usually badly cut pipe with jagged edges leads to damaged o rings
That's a different matter.
I'm referring to fittings, that I'm demounting to make pipework alterations, and finding they have failed internally... Practically fall apart when pipe is removed.
Worst ones were 28mm Hep2o elbows.
You can hang rads on plasterboard using the correct fixings.
It depends on the size and type of rad.
Timber grounds are always preferred but not always feasible.
You wanna try hanging them on paramount partition board! That's fun! Lol.
