Replacing cast iron bend with limited space
22 Jan 2012
UK
Hi all,
I need to replace what believe is a 1 1/4" waste elbow, serving a basin. Installation circa 1960.
I think it was cast iron. ID 33mm, OD 38mm (Of the pipe inside the remains of the fitting )
As you can see, the part coming out of the wall doesn't have much space.
Attached is a photo of a very similar setup a couple of metres away.
Any help appreciated as to what to use, I have found some rubber fittings with jubilee clips, but hope there is something a bit neater.
Can you replace to outside in pvc? If not, any room to cut and get a universal coupling on and take to outside in pvc? Probably what has been done in the 2nd photo.
Cannot really replace to outside as it’s under the floor. I could get a universal on if I cut the render out.
The second photo is I believe original. I suspect it will fail next as well!
OP,
Both set-ups look well shaky - as above, bite the bullet and replace the pipework in plastic.
Why not post interior pics of the floor below the basin, & the other situation?
Waste pipes are best run to discharge in trapped gullies.
OP,
This is in a youth hall I volunteer at. Budget is close to non-existant. I suppose I could core a 45mm hole and run new waste out at the wall level...
What looks shaky? The iron pipes feel solid, but the exposed bends clearly are not.
Also why are they best into trapped gulleys? They are trapped behind the basin which stops all smells?
