Hope someone can help me out..
I drained the system a few days ago to change a rad valve and alter some other pipework for a towel radiator.
I now have air trapped in the system on both sides:
- Two radiators don’t seem to heat up, all air has been bled from them.
- The boiler is making gurgling sounds when hot water demand is on, hot water IS heating up so it’s not completely locked out but more air is trapped in the cylinder coil.
It’s a Y plan with a pump and 3 way diverter valve. There is no automatic bleed valve in the airing cupboard and there’s a vent pipe going to the loft tank.
Total of 8 rads, 4 of which are downstairs and each rad downstairs has a drain off valve.
I’ve read the suggestions such as pushing mains water up the drain off valve which will push the air up to the vent pipe.
Also a suggestion is pushing mains in the loft down the vent pipe to push the air back to the tank.
I’ve also alread you can use a wet vac on the vent pipe to suck the air out.
How do I go about getting rid of the air lock and bleeding the air from the cylinder coil?
Any help appreciated to sort this before winter.
Thanks!
Thanks!
