JUST BRUSH CLEANED THE BATHROOM DRAINS, THICK JELLY LIKE SUBSTANCE?
27 Feb 2025
I brush cleaned the drains in the bathroom because the water was backing up in my shower and basin.
There was the usual black slime that I know about, but, there was also opaque thick harder than jelly, softer than rubber stuff that also came back with the brush.
It reminds me of when I put fairy liquid into my car's windscreen washer bottle and it clumped up and blocked the pump, so is it residue of liquid soap/toothpaste/shaving gel, or is that also bioslime, AND what should I do to clear this away other than brushing the drains wvery so often?
Thank you.
Soap scum possibly? Are you in a Hard water area?
Don't think there is a lot that can be done, very hot water may help keep things flowing, if not afraid it'll be a good clean out as and when required.
Do you use the blue toilet blocks in the cistern. They can leave a residue that sounds like what you are describing
Similar threads
