Hikvision CCTV system
18 Oct 2013
London
I have a Hikvision CCTV IP addressable NVR system (model DS-7616NXI-K2/16P) with 10 cameras (capable of 16) and possibly a 8gb or 10gb drive. Had it professionally installed by the installer is difficult to get hold of.
Since about July, when I try to view historical recordings on my phone, the green dot that appears against historical dates does not appear until some few minutes after I am playing with the app or trying to view footage. its as if there is no historical recording except for today. Also when I can view recordings for yesterday or few days earlier, it only shows it starting from midnight and I cant scroll forward through the day. After a few minutes the dots will appear against the historical dates (I can usually access about 3 weeks of footage given my capacity drive) and can scroll through the time lapse of the days. It's as if there is a lap before the historical footage appears. My questions are:
1. Would formatting the drive help clear any issues? The firmware software on the NVR is the latest from what I can tell when I try to do an online update.
2. After watching footage on my phone for about 4-5 minutes, it times out and I have to refresh and do it again. It stop in landscape mode and goes to the main screen again. Very annoying and feels under developed.
Anyone got a solution to these issues and are these general issues with Hikvision?
Alas the online update check from NVR isn’t what I would call reliable way of checking it’s up to date.
Your saying there is a day before all the slots of your recorded footage show on the calendar?
The time out unfortunately is to limit how long you an access footage on a phone as it uses a cloud connection so millions of people viewing 8mp recorded footage is a strain on resources.
You can setup a profile that connects directly to your NVR via its external ip address, or internal ip address using a vpn for remote access.
Then the time out would not apply.
Hi
What is the solution to the first part of your question?
I'm saying that the green dots on the calendar do not appear for quite a few minutes after, so initially it feels like there is no recorded footage for the days shown.
I would have to guess phone connection to cloud as just done some tests and mine is instantly there. Try testing with a WiFi connection and try testing with mobile data only and compare.
come on I can spoon feed if you really need it it but Google search setup local hik connect.
Show us how far you get and if you get stuck pop back
