Central Heating Pump
23 Nov 2003
How does the pump actually circulate the water around the section labelled "Boiler system"? I can't work out from the diagram how the water gets pushed/pulled.
OK thanks. My central heating is set up like this, but without the 2 port zone valve on the radiator part.
I can switch the radiators on via a room thermostat without the underfloor heating on, but when the underfloor heating is on, the radiators are on regardless of what the room thermostat is doing.
I am trying to work out why. :cry:
Because it has not been correctly wired with seperate controls on the UFH and the radiators.
Tony
