Soldering next to a gas pipe...
  • Thread starter Thread starter imamartian
  • Start date Start date
I
imamartian
Hi, i'm about to solder a hot and cold supply for a new sink, but the joins are next to (15cm away) the main gas pipe coming into the house - so i'm a bit nervous.
Should i turn the gas off while i solder the water pipes, or should it be ok?
a great big plank of wet wood between the pipes should give protection
a burner flame can easily be 150mm long even if its not visible
thanks guys.
I have a soldering mat, just bothered about any gas in the air... although i know that shouldn't be possible.
and just measured and i'll be 6cm away :shock:
I hope this is a steel or copper gas pipe and not a plastic one!
Tony
