S
saxondale
no, water is not a solid, its a liquid, i also said microwaves can go through "most" solid objects, i never said all solid objects.
for what its worth microwaves can go through brick walls, timber and most other materials, except metal, which is what most boats are made of
if the brick wall was moving the microwave would detect it, its got nothing to do with the material but everything to do with doppler effect - objects nearer return the reflection quicker than objects further away, take two measurements and you can work out movement, add a third and you can calculate distance.
