Firstly hello . Hate to start DIYnot forum life with a question,but needs must.
Can any plumbers help me with a problem I have .I have recently installed an underfloor heating system to the ground floor extension of my house (approx 45m2) The manufacturers instructions state that it can be added to the radiator circuit flow and return,but given the long heat up times & requirement for night time set back etc. I can see this being A, expensive to run & B, uncontrollable. Additionally this seems to be drawing the flow from the existing ground floor rads.
What I need to know is ,can I run my ufh supply pipe work directly to the primaries on the boiler,and add a motorised valve on the flow, controlled by a programmable room stat.(honeywell cm67),and fire the boiler independently of the Honeywell Y plan thats installed. Sort of a Y plan + system.
I suppose what it boils down to is can you add an S plan ,to an existing Y plan.?
Cheers guys .
Cheers guys .
