First post here so hello every one
I've a problem with out boiler, it's a Baxi 105e Instant, probably about 5 years old, been fairly regularly serviced. A couple of months ago it started producing no hot water other than that stored by the pre-heat function, does the same with CH on or off, CH works fine.
Regular plumber we have used for a long time has retired and moved away
Had someone else in to have a look, ............ and he went away scratching his head.
Now I've been involved with the building trade all my working life and can certainly find my way around the basics, so at least if I can understand what the problem might be I should be able to find someone who can get it sorted.
The diverter valve push rods both actuate, as does the diverter head push rod, the dhw sensor seems to have the correct resistance, which falls as it gets hotter; the micro switch on the dhw valve is making contact when it's supposed to. All the neon's light correctly and no flashing (warning) lights.
When you turn on hot water the burner ignites as if to heat the water, it will go out after a short while, most likely as the water is going nowhere and getting too hot, then ignite again ........... etc
It clearly seems somewhere water is not being diverted into the dhw circuit, but as far as I can see all the controls are doing what they should be ................... to be fair I can see why the guy said "I don't know" and at least I prefer that answer to someone swapping loads of bit's just in case.
Sorry for the long rambling post, any idea's gratefully received.
Dave
Dave
