On CH demand, boiler fires up, pump runs, gradually heats up, reaches max temp (80 deg led) in about 30 seconds, flame extinguishes and pump continues to run until temp decreases to 30 deg led before the boiler fires up again?
Result is that the rads get hot but not too hot to touch. Problem is that they dont seem to radiate enough heat to actually raise the temp of the rooms to much more than 19/20 degrees. This is despite TRVs being on max.
Have checked all rads and they didnt need bleeding. Boiler pressure constant at about 1.5-2 bar. DHW demand / instant DHW demand all seems to work properly (i.e. switching on/off when needed and returning to CH mode afterwards).
I have about 13 rads in all. If I switch off some of them then YES some of remaining ones are too hot to touch.
Wondered whether the pump isnt up to the job??? It was replaced during the summer - its the same as the original but has the words "Low Energy" on it. Do you think this pump is not beefÿ enough??? Or maybe the entire boiler is just not capable of heating so many rads??? Maybe I need to replace it with something with a higher central heating system capacity???
Would appreciate anyones thoughts on the matter.
Many thanks
Many thanks
