S
sturharv
Need a little advice guys, I have a large capacity sink located in a utility room about 25-30m from the cylinder. There is currently a 10 litre mains pressure HW store under the sink (which is normally more than adequate for what you normally would use the sink for), but there is not enough hot water for what the sink is now wanting to be used for i.e. hand laundry washing, where there may need to be 2 or 3 sink fills at a time.
I have seen these electric 'instant' tankless units but I am of the understanding that the flow rates aren't that good, plus they need their own electric supply from the consumer unit, which is not to easy to get to. I know there are instant gas heaters out there but putting gas in that area would be difficult and costly.
When the new laundry was built there was a cold and hot supply brought from the main house (for the taps, washing machine etc. but due to the length of the pipe there would need to be a lot of HW drawn off and this would take a lot from the cylinder. Could you connect this 'capped off' hot supply which is currently under the sink onto the heater unit which would help the recovery of the hot water in the 10 litre unit, although I am aware that it will draw off from the main cylinder, but you wouldnt need to wait ages for the hot water
Any other suggestions please?
Cheers
Cheers
