okay i have a volker linea 24 combi boiler, with what looks like 2 problems, First i have a problem with loss of pressure, i've checked the radiators ect and cant find any leaks, i have a small semi detached house. i was told to check for leaks and then check the pressure vessel, i found no leaks the moved on to the vessel, i used a tester to test the pressure, when i tested water came out aswell as air the reader read 0.7 psi, from what im told the vessel needs replacing? can this cause the loss of pressure?. second is the problem with trying to get hot water from the taps ie running a bath the only way to get hot water is to run it slowly! if i run it fast the boiler seems to turn off so i turn tap off turn on again and it egnites. i noticed the temprature gauge showing bout 30-40 then when i turn the taps off see the gauge showing 90. from what i hear this is the is the heater exchange proberbly due to the repressurizing?
Now can i do the work myself are these hard jobs?, i could get the parts replace them and hopefully solve the problems and if i still have loss of pressure i know i still have another problem. or is it just best to get sum1 out, i just don't want to be wasting money if i can do it myself.
i have posted b4 about the loss of pressure sorry for the posts
http://www.diynot.com/forums/viewtopic.php?t=112879
