Guys,
Was called out to a Ferroli Modena where the customer said the DHW was staying hot for 20 secs and then going cold. From reading through the forum this would suggest a faulty thermistor. Boiler hasnt been serviced for 3 yrs. 18 mbar working pressure at gas valve on CH. 12 mbar for HW and 7mbar for CH on outlet.
I went round tonight for a recce. When i got there pressure was sitting at 2.5 bar so i nearly had to unscrew the PRV the full way out before it started to drop (this is how it says to drain it in the manual). Needless to say we now have a small drip from it so it will need replaced.
When the HW was cold the Therm was reading 14 K Ohm and when i got it going hot it read 2 K ohm. So it appears to be okay.
Anyway when i went to put on the heating after running the HW it would only stay on standby. I had to reset the boiler to get the CH to come on and then it ran away merrily. Then turn on HW, boiler goes off, cuts back in for HW and it is fine, turn of HW and CH goes back to standby again.
Im going back round tommorrow so what do i need to bring???
G
G
