fused spur HELP
29 Dec 2007
Cambridgeshire
HI. I want to install a pump to help my water pressure. I need to wire it to a fused spur. I already have a fused switch in the cupboard can i attact it to that. or should it be done another way
URL=http://allyoucanupload.webshots.com/v/2005020928537393393]
[/URL]
Is that FCU supplying the wiring centre, or supplied from it?
And yes, I know that all you've asked is how to do it, but have you heard of Part P?
Yes, we can see it.
If that fused spur is feeding your CH, the output should not be used
You may be able to wire another spur to the circuit feeding the spur. How many cables are feeding the existing spur?
I'm starting to get the impression that you don't yet have enough basic electrical knowledge to be doing this job.... :?
very simple...
get a copy of the yellow pages, find the section for electricians, find one that's registered and give him a call..
or an electrically registered plumber who can do the pipes for you too..
There might be.
Depends on what you have there already, and photos of white plastic accessories don't show the electrical connections....
