Just curious as to whether anyone can explain the reasons why the conventional way to wire lights is in series (i.e. from one to the next, with switched live between the rose/ dist or lamp itself) is better than supplying each lamp/ group direct from the switch (i.e. supply to multi-distribution point > to switch > to lamp/ light).
For example, if I take a simple lighting circuit consisting of 2 pairs of lights which are to be switched independently.
With the conversional way of doing things, we have 6 runs of cable :
1. supply > lamp1, lamp1 > lamp 2 lamp 1 > switch 1,
2. lamp 2 > lamp 3, lamp 3 > lamp 4, lamp 3 > switch 2)
Doing it in parallel (?), seems more efficient in terms of cable with 5 runs :
1. Supply > switches
2. switches > lamps 1-4
The obvious downsides I can think of are more conductors runing into the back of the switches and (maybe) a bit more work in 1st fix since everrything has go to be run back to the switches..
But, aside from this, am I missing anything else ? Are there any other advantages (e.g. circuit performance) anyone can think of?
Cheers.
Cheers.
