I had this fault and got it fixed my self by changing the ignition pcb part no vokr 1837 . my boiler was not igniting I had no hot water or heating for 6 days. I checked gas inlet and outlet to unit, then 240v and 24v to ignition box as described in user book page 44. Alway refer to installation & serving instruction book for problem. this book has instruction and diagrams. if you don't have this book see if it's available to down load or ring volkera on 0870 333 0220 they may be able to send one to you. My error code was 01 and I had no spark in unit. Error codes on page 38 code 01 , page 39 then A2 page 41 , then page 44. Diagram on page 54 top letf 1837 page 58 for part description pages 59 and 60 for circuit layout. Page 60 M14 240volts pin 1 and 2 , M4 24 volts on red and black if ok change ignition controller box.
I hope this helps all people with problem with ignition and not starting modes as this took me some time to work out.
