hi
just been to my friends house who has not so long ago had his gravity heating system "upgraded" to a c-plan.
this was supposidly to stop the boiler banging.
hes, had nothing but trouble since installed, heating settings overiding hot water, etc.
we were just discussing it, and i thought i'd have a look...
i found the guy had fitted the following new parts:
28mm 2port valve on the hw flow... (didnt have 1)
fitted a new clock. (had old time switch)
fitted a cylinder stat... (didnt have 1)
I honestly couldnt work out what he had done, it clearly wasnt a cplan... he'd only used the brown and blue of the valve.
i tested the brown wire it was constantly live reguardless.
he could only select hw or hw&heating... it was a 2channel clock... i thought the whole idea of the valve was to add more control to the system? he couldnt select ch only.
somthing just seemed wrong, so i've just totally rewired the lot for him.... now working fine with indipendent controls of bother hw and heating or both.
the house has a warm air system, it has a very big motor on the back.
they had wired this motor directly to the clock, bypassing the relay for the motor and thus bypassing motors own dedicated supply...and just upped the fuse to a 13a
anyway could any one shot some light onto how this thing was wired, i think it was just a botch, i could be wrong tho... they could be a reason for fitting a valve and having it in the open position all the time i don't know :S
I the guy who fitted it simply said its ok and refused to come out.
is he right?
mick.
edit: apiologies if u cant understand this message, i aint too good at explaining things
is he right?
mick.
