shower
21 Jan 2008
Lincolnshire
just bought a 10.5kw shower, wat size cable do i need?
how is cable measured 6mm 10mm, got one in the loft pre-wired that mesures 14mm wide grey wire?
how many amps does 10.5kw draw?
Most probably 10mm², but you should verify the design before you start installing
By conductor cross sectional area, what do you mean you have one pre-wired? was there an electricaly heated shower there before?
Power is equal to volts multiplied by amps
Are you aware that installing a shower circuit requires LABC notification?
