glow worm fuel saver mk2 clanking noise
Both are aggresive chemicals and only used with caution.
The heat exchanger on a glowworm has vey small water ways and is prone to a blockage. (Ihave cleaned one this year alredy).
Fortunately, they are so easy to remove and clean I generally get my apprentice to do that job nowadays.
As I speak I have my mothers heat ex in my garden fizzing away!
Dave[/quote]
Thanks Dave, How much this can typically cost !
OR is possible I had opened or closed a wrong valve somewhere.
Thanks again for your help !
could be air or a blocked cold feed. did the header tank empty when you drained system
Yes the header tank did empty and even left it running to flush out any muck !
Partial or full blockage in the heat exchanger will be your problem. Remove it (or get someone that can) and clean it out. DS40 or D block will do it. Replace it and let me know know how your circulation is then.
Dave
Thanks for the reply.
Sorry what is DS40 or D block and where can I get it !
Dave
OR is possible I had opened or closed a wrong valve somewhere (Please see my previous comments).
is flow pipe from boiler getting VERY hot (should not be more than 80c)
is it very hot even when turned to a low setting, if so I would be suspecting the boiler thermostat is faulty.
