Sorry to butt in
Not sure quite how much of the above is serious!
But...
Regardless of the thickness of anything, if its surface temp is lower than that of the air surrounding it, and that surrounding air is humid, condensation will form on the cooler surface as soon as the surrounding air is cooled to its dew point by that surface. At this time the moisture in the air will 'drop out' of the air onto the cool surface. The dew point will depend on the moisture content of the air. The higher the humidity the higher the dew point. It is, therefore, inevitable that condensation will form on the cistern, a mirror, the wall tiles, the window etc when you take a shower, unless these surfaces are heated to a temp above the dew point, whatever that may be. Or you have a cold shower!
I may be wrong but it seems that this is what Corgigrouch is saying and what Bamber is disagreeing with.
Or did I miss something?
