Mira88 shower replace piston assembly
12 Feb 2008
Surrey
Hi I have a problem with the water supply we are getting good pressure
on the cold but only now getting very low pressure/supply on hot. :lol:
is this mixer fed with mains-pressure cold and tank-pressure hot?
I meant, does the cold supply come straight off the mains (not from a tank)?
that's the wrong way to do it. a shower mixer has to be fed hot and cold at the same pressure. As you have a cold water tank the way to do it would be to run a cold waer pipe fed from the tank. You can use a pump afterwards, that will increase the pressure of both hot and cold.
