Hi all. On a new open vent system, i know that the pump goes after the vent pipe and cold feed, but my question is would it be best 4 the pump if it pumped vertically upwards, vertically downwards or horizontally? Thank u 4 your time.
Hi Bamber gaspipe and thanks 4 the reply. It is actually at the same level as my pump. But why the position of the cylinder would make a difference? Ta.Hi all. On a new open vent system, i know that the pump goes after the vent pipe and cold feed, but my question is would it be best 4 the pump if it pumped vertically upwards, vertically downwards or horizontally? Thank u 4 your time.
depends on wether your hot water cylinder is above, below or on the same level as your pump.
Hi and thanks 4 the reply again.[quote="dotto";
Because I don`t know wether the boiler is a freestanding, floor mounted boiler with the pump situated in your kitchen & the hot water cylinder is on the first floor.
Provide some details of your heating & hot water layout.
Whichever way your flow pipe is facing/ flowing make sure the pump is flowing that way.
Usually indicated by large arrow on pump stating ``Hey. D*ickhead, make sure I`m pointing this way``.![]()
Boiler is on ground floor and hot water cylinder and pump in the airing cupboard, cwsc and f & e in the loft. With this layout would you install the pump so that it pumps upwards or downwards and why?
Thank u 4 your answer Tony. The reason why i am asking thios question is because i have received different views on this question. Some plumbers say that it should be pumping downwards so that you put less strain on the pump if pumping downwards and consequently it will last longer. If you put a deaerator in the system or you made an H to get rid of the air you would fit the pump pumping downwards or at least that is the argument that some plumbers seem to have. Since i know you are very knowledgeble, do you think they might have a point? Thank u 4 your time.A pump will self vent if it pumps upwards!
However the over riding need is for the system to be vented if its open vented.
If sealed then adequate air vent points are required, competent installers use auto vents and then close them when all air has been ejected.
Tony
But it will be better and last a dam sight longer Horizontally or vertically up
Doitall thank you very much 4 your time. What problems would you envisage if the pump was pumping downwards away from the vent pipe and cold feed?But it will be better and last a dam sight longer Horizontally or vertically up
No Dotto; They haven't got a point, They are wrong the pump should be horizontally, with the axis of the pump slightly tilting upwards, or vertically with the arrow facing up.
Eh? Pump axis should be horizontal, as there are no end thrust bearings. Horizontal flow usually doesn't give problems with air in the pump, if that's what you meant?They are wrong the pump should be horizontally, with the axis of the pump slightly tilting upwards
. Some plumbers say that it should be pumping downwards so that you put less strain on the pump if pumping downwards and consequently it will last longer. Since i know you are very knowledgeble, do you think they might have a point? Thank u 4 your time.
The pump rotor should always be horizontal or inclined just a few degrees down to the vent screw. This is to stop air collecting at the vent screw and allowing the bearing at that end to run dry.
