Hello,
I have a potterton puma 80 permanent pilot boiler, which is sporadically losing it's pilot. Sometimes it will run for a few days, sometimes it loses it overnight, or during the day. I have replaced the Thermocouple twice now, just to make sure, and it's still doing the same.
I have previously replaced the DHW pressure actuator, and the main fan, due to other problems. Other than this problem, the boiler is working fine. A boiler guy in work, said it could be a faulty gas valve, but having read previous posts I see it could also be a faulty overheat stat.
Will the overheat stat knock the boiler off when it's not in use?
Has anyone heard of one of these boilers needing a gas valve?
Any suggestions about what else to check?
Thanks,
Col.
Thanks,
Col.
