Even if not damaged (i.e. I can see how the right combination of cable size and clip size could have cables on edge held in place by clips but not under any pressure), if they're like that wouldn't you have to consider grouping factors?
How much are you likely to need?You have little option but to clip it to the edge of the joist, and derate accordingly.
Tray for the whole loft is a bit overkill.
I guess people would be less likely to tread on a cable tray, but that wouldn't help with stuff being dumped on them. With the type of loadings likely in a domestic loft, what's the longest unsupported run of cable tray you can have? Would it be feasible to run it parallel to but between the joists?I don't like to see cables clipped to the top of joists as there is too much risk of them being trodden on / having stuff dumped onto them.
...or 101 if the insulation exceeds 100mm
Here is another simple method to keep cables tidy in the loft.
You could have used clips the same colour as the cable
Johnd said:I'm just lacing up my hobnailed boots...
Dont like the look of those 2 runs of CAT 5 held by just the one clip!
I think the juxtaposition of contrasting colours makes a bold statement, and by challenging the blandness which would otherwise afflict it, lifts the installation to a level where it can be an inspiration to us all.You could have used clips the same colour as the cable
