sanding down coving.
2 Mar 2008
Herts
Whom ever painted my coving in the bathroom did not use half-paint half-water mixture on the first coat. Now it's cracking.
I need to rub it all down or use an electric sander. Ideally I dont want to using elbow grease.
Ideas anyone?
Get a dense foam sponge about 8"x6"x4" and use this as a sanding block, when you push it into the cove it will mould to the shape and make the job a little easier. Cant see you can really use an electric sander on a job like this. :wink:
Ideas anyone?
How do you know it was the mix? Could it not also have been steam, environment, painted over dust, grease, wrong paint, etc/etc, or where you actually there when it was done.
ok, i dont know is the answer to that question. why do you ask? will it make any difference to my rubbing it down?
Hope I'm not too late!
Go very carefully and use a really light glasspaper - If its the plaster coving its very easy to damage the paper surface and once you get tears in that they are very difficult to hide, ditto the paper covered polystyrene cove. And with the general polystyrene coves the slightest pressure can leave a permanent dent.
If its only the coving thats cracked, it may be one of the hi-density polystyrene coves which are ultra smooth - hence the paint won't soak in and if its been put on too thick will tend to craze. I always reckon to use several thin coats when I'm using this stuff.
Trust me - I've been there!
thanks for the heads up. the coving is made of something that resembles plaster. its really heavy and no way will it dent.
try a flexible sanding block or some wet and dry using the sponge method mentioned :)
