Can one of the resident experts take a quick gander at these couple of pictures for a proposed shed install (in Scotland).
All pretty straight forward but not sure of the easiest way of doing the lighting arrangements.
Lighting:
I already have the 60" Flo tube installed ( currently powered when required by an extension reel - not ideal ) , This needs to be controlled by a single switch by the door.
I also want a 100 or 150 watt PIR controlled security/area flood which will be switched on all the time and just be controlled by the units own PIR/ movement detector.
I may also add an external switched dome light with lo energy bulb for when I sawing bits of wood outside at 11 pm in the summer as we do...
Supply to shed:
I've rummaged in my box of bits and pieces and found a couple of 63A 30ma 'Shower' RCD's . I could incorporate one in the circuit if required ( maybe to protect the buried cable ??)
I already have some 4mm 2 core SWA cable that i could use ,or would buying some 3 core for this be better, it is only about £20 for the amount i need so safety is my main concern here
Shed Consumer:
I've already got a 2 way MEM 2000 Garage CU with 6A & 16 A mcb's with 63A 30ma combined main isolator switch/RCD.
http://photos.imageevent.com/sidandcoke/generaldumpinggroundforgashpiccys/shed option 1.JPG
http://photos.imageevent.com/sidandcoke/generaldumpinggroundforgashpiccys/shed option 2.JPG
Lighting:
Supply to shed:
Shed Consumer:
