Hi, I have a recessed outside electric meter cupboard on the side of my wall but just inside a drive thru archway which has a storey above.
This archway is only 7.5 ft wide but 24 ft long which i intend to brick up & split into 2 rooms (it was once the kitchen years ago).
Its only purpose these days is as a drive thru to the garage at the rear which is a tight squeeze due to the width.
If I brick up the front & back & turn the front half into a downstairs bathroom do I need to have the meter & cupboard moved to the front of the house?
From a moisture point of view i cannot see it as a problem for the very reason that electric meter cupboards are sited on outside walls exposed to the elements.
I could understand if i was talking about the consumer unit or something. Furthermore as previously mentioned it used to be a Kitchen so hopefully the man from Building regs will not insist on me having it moved before approval for the archway to be converted once more back to a room.
Incidentally having checked costs of shortening the electric underground feed by 1 metre onto the front wall the minimum fee is £533, that's once i've dug the new & existing trench,laid ducting/draw rope & electric warning tape & fitted a new recessed box to the front myself. For the £533 they just disconnect from the existing meter & reterminate at the new!
Thanks in Advance
Thanks in Advance
