Help please! I have an old brown box style thermostat on the wall in the hallway. I thought it was redundant as I had a new wireless thermostat fitted to a new gas CH boiler a few years ago.
Today I disconnected the thermostat wiring and my CH boiler has stopped working (apart from running for a minute every now and then, but no heat getting to rads). So, unless it's coincidence, it seems that the old thermo needs to be connected in order to run the CH gas boiler.
Problem is ... I never noted the wiring sequence and don't know which terminal the Blue, Yellow/Green, Red & Yellow wires should go to. Inside the cover of the brown box there is a wiring diagram which (from left to right) reads:
2 3 1
There is a U under 2; a T above 3 (but linked to the 2); and under 1 there is an N above the L (phase).
Before a call an electrician in, any suggestions please?!
Thanks.
Alison
2 3 1
Thanks.
Alison
