NATIONAL EMERGENCY - Wife cannot wash her hair - no pressure
5 Apr 2008
Suffolk
Hoping someone can advise on a plumbing problem. I have no plumbing knowledge so apologies for describing this in laymans terms. Just had a trusted and experienced plumber fit me a new bathroom suite with mixer taps. Once installed, hot water pressure is very poor – a slow stream of water from the basin and bath mixer – too slow to fill a bath. Prior to the change, pressure wasn’t exactly great – didn’t have much force behind it, but is certainly worse now. We’ve always had decent cold water pressure, but oddly the cold now seems to have more pressure. The wife think its directly related, like some of the hot pressure has somehow ‘transferred’ over to the cold, but I can’t see how that can be as I think the cold/hot are on two different ‘systems’.
We’re in a flat, with the hot water cylinder tank (immersion heater) in the airing cupboard just a couple of metres away from the tap outlets. We have no loft, so no cold water tank. Followed the incoming water feed past the stopcock and think the cold water is directly from that feed.
My only thoughts to resolve the problem is to buy and have fitted a pump, perhaps located next to the hot cylinder tank to boost the pressure to the basin and bath.
Is there a problem somewhere that is causing the poor hot pressure? Would a pump solve it?
With thanks,
Mark
Where does your HOT water supply come from? Tank on the roof? Mains? Tank built into the HW store?
Agree with Kevplumb here - sounds very much like the tap you selected/bought/specified is only suitable for a higher pressure than your system provides. Was there any spec. with the tap indicating minimum pressure required?
darn, no didn't check - didn't know there was a difference. brought the bathroom suite with taps from an online store - wasn't much detail posted with the product, like the specification of the taps, but even if there was, i wouldn't have understood what it meant - just thought a tap was a tap!
what should i do? replace the taps to regular ones, like i used to have? the basin thou has a single hole so think i'm now forced to stick with a mixer. i'd really like to have more oomph in my hot water for when filling the bath. would a pump achieve this, and could i have one off my immersion heated tank?
mark
cool, ok. at least there's a solution - just need to pay out some more cash. thanks all!
Just had a trusted and experienced plumber fit me a new bathroom suite with mixer taps. Mark
Surely this "experienced plumber" checked the suitability of the taps and advised you accordingly before fitting them?
In any case he is best placed to advise you on the cause of the problem and about a shower pump!
What did he do when it did not work properly? Just suck air in between his teeth and say" I have never seen that before?"
Whilst he may have been working as a plumber since he left school twenty years ago at 14, he certainly does not seem to have learnt much from his experiences!
Tony
that's correct - pretty sure i've got a combination cylinder.
m.
must remember to read the op
thanks guys - all good advice. talk about learning from these experiences...the hard way!
mark
