- Joined
- 2 Dec 2004
- Messages
- 706
- Reaction score
- 8
- Country
Ferroli combi Optimax 31C. 7 rads + 1 towel rad.
We had our installer back out to flush our 6 month old system yesterday because the water was dark brown and rusty. I don't think he flushed it properly when he installed.
Since doing this most of the radiators are scorching hot. The towel rad is the hottest (untouchable) and nearest to boiler. The ones near the end of the pipe runs are hot enough too.
I tried to balance the system but I can't get a temperature drop. All rad valves were left full open by the installer. The LS valves are practically closed and i'm still seeing only 5 deg delta T. The combi is set to 80 degrees flow temp.
There also appears to be more flow noise now than before. There is also an occasional whistle from the boiler and there has been 2 occasions of loud banging too, like water hammer. I thought this may be air which should come out of the auto-vent on the boiler. I have bled all rads when cold and they are free of air.
I can't believe that a 6 month old system could have been so dirty that the flush made this much difference. Therefore could the installer have done something which I need to put right?
Many thanks
Many thanks
