I have recently installed a new consumer unit and I'm having problems with the RCD
All the ring mains are wired on the RCD side of the unit, nothing else (I have gas cooker / heating and no elec shower).
The RCD will trip whenever I put any load on it above, say, a table lamp. I have also totally disconnected each circuit in turn (L&N) and tried again but the same problem occurs.
Further to this the test button doesn't work (I'm guessing because not enough load is on the RCD).
I have checked the connections into the RCD and even swapped it with a new unit, but the same problem occurs.
Help!!!
Help!!!
