Ok, my bad definitely for somehow doing the sums and ending up around a quarter of the value I should have had. I don't know how.
I am reasonably competent with electrics, DIY etc. (although those of you reading this will probably not agree with this, I was being stupid today). I do not want to touch the RCD box/main breakout box. (plug in/plug out fuse/RCD that is all). There is no isolator between the mains supply and this box for a start.
The situation is as follows. I replaced the shower in the bathroom with a slightly lower powered one, 10.5 > 9.5 KW. That went OK.
I have later on changed the radiator and changed it to a towel rail with an electric element. The element is 300W.
I came to the point where I want to wire this in. The previous situation was: The wire runs up the outside of the bathroom from the RCD box, to the loft, to the double-pole isolator, ceiling mounted well away from the (neon+physical sign), then to the shower through the loft/wall. The RCD was rated at 32A (this was where I should have realised what was wrong).
So I thought, as the two items were in the bathroom, they could sit on the same circuit (the original ciruit would have enough lee-way for a start). The wire for the towel rail could be run, uphill through the wall, isolating any switches/joins to be outside of the bathroom/wetzone. The RCD was 32A, so I could use a 32A junction box, and take a feed to the wall, fuse plate this on a pattress box, and through to the towel rail.
I turned off the RCD, and cut the cable. It is at this point, that I realised, this is not 6mm/32A cable.
The run from the RCD to the isolator is somewhere between 5-8m (That is measured horizontal/vertical, so the difference would be the pythagoras blah-de-blah). It is more that 5m, hence the 10mm cable.
So my question is
A) do you think I can suitably use a 60A junction box to re-join this cable? I would move the join to under the floor (between ground and 1st), It would be around 3.5M from RCD, junction/join then ~3.5M to isolator.
The junction can be nicely fitted to the floor joist quite close to where the cable currently runs. The downside to this, it is around 30cm from where a hot water pipe for the central heating runs. If I can situate further away from this pipe does it make it more suitable (even if it means a longer cable run, the pipes do run close to the cable to start with).
B) If A is acceptable, is the heated rail acceptable? Or should I hard wire this (with the fuse plate) to the ring mains? This doesn't sound good to me, however, I don't like the idea of a plug/socket.
Thanks in advance. (just as well I have the bath/hot water working now!)
So my question is
