Ok my bad. I must have turned off the tap to the big tank while trying to map out my system. I turned the tap and water started filling the tank up. There is a thin pipe (15mm?) which goes both into the F&E tank and the bigger water tank. This pipe has two metal taps, one next to the F&E tank and the other used for the larger tank both are open. Another thicker pipe leads from the cylinder and goes up to the bigger tank which is warm. Another pipe of the same size also goes up to the bigger tank, this pipe has a red valve which is fully open and is cold to the touch.
I am going to recheck everything and map the system out. I'm guessing I may have a blockage somewhere. Thanks to everyone for their help so far..
