I have a Jaguar 28kw Combi Boiler,
Over the last week, the hot water has gradually stopped working, at first you had to turn the HW tap on full to get the boiler to fire up. This progressed until 2 taps had to be turned on full.
Now, NO hot water at all.
Central heating is fine, water still flows from HW taps but it is cold, just doesn't fire up the boiler to heat it.
Instructions say" if no hot water when taps turned on, check flow meter or that 'O' ring is not blocked.
Are these things the same as the diverter and diaphragm?
If so, how do i change the diaphragm, i've had a look and think i know where the diverter is, although this seems to have a dial on the top which adjusts pressure? it also has the safety (overflow) pipe coming out of the other side.
Am i looking in the wrong place, any idea's how i change the diaphragm if this is the problem and where i can get spare diaphragms from?
