How do
We are in the process of making a double length garage; car at the front, workshop at the back. I've been looking at the previous posts here and looking at this interactive doodah...
http://www.planningportal.gov.uk/uploads/hhg/houseguide.html
The old garage was in two halfs, brick at the front end and concrete panel extension at the back (on a concrete base). Total floor 27 square metre-ish. The concrete panel section has been knocked down already. The new garage (30sqm ish) will in effect be further down the garden as it will start where the old brick garage finishes. The brick bit will be knocked down once the new garage is in place.
1) We plan on reusing the concrete panels for the new garage (we have a stock pile of extra panels that the previous owner left behind). The only problem with building regs that i can think of is that the garage is on the the boundary and not a metre away as required if the floor space is greater then 15sqm... but the old one was on the boundary too so not sure if thats ok, seeing as the new garage will be about 5m further down the garden?
2) On another note. The old concrete base sits about 9" above ground level. We have cleared the ground around the old base as far as we wish to extend. We have a huge pile of building rubble from another job (mostly whole bricks), can we use this anywhere in the new base at all? Either as sub base or chucked in the concrete itself. Also, should we be tying the old base to the new base somehow?
A thousand thanks in advance.
Jas
Jas
