Hi Everyone,
I hope someone can help. I have a fairly new central heating system (about 1 1/2 years old) which I have never quite managed to get the hot water right on it.
It's currently coming out scalding hot, I've tried lowering my tank thermostat (it's now down to 45ish) and as far as I can tell the thermostat is functioning correctly (I've run the boiler and sat up by the tank and can shut the boiler off or on by lowering or raising the thermostat).
My common sense tells me that if I reduce the thermostat on the boiler itself then it shouldn't heat the water up so much. Would this be a correct assumption? I don't want to mess around with it too much if I don't need to. I have dropped it down a fraction but it doesn't seem to have made a lot of difference.
Any ideas or suggestions are gratefully received.
Cheers
Dan
Cheers
Dan
