Hi all
New post here, and please bear with me, I'm not much good with forums, DIY & whatnot....
My dilemma is that I have an old period property that I want to insulate. My first consideration is the sloping roof.
The attic area itself is a large area, designed as a walk-in space (The stairs lead right up and there is no need for ladders etc for access), so assuming that I do this right, it has the potential for a loft conversion. Being a period property though, I would like to keep the joists exposed, as this is part of the charm of the building.
The problems start, however with the fact that the joists in the roof are only 80mm thick, and, being a period property, I have to be very careful with the material that I actually use. Based on what I have read, I have to leave approx. 50mm ventilation in order to prevent condensation. This gives me only 30mm to play with, and even less if I want to keep the joists exposed.
So basically, I'm asking a few questions here....What is the minimum space I can keep for ventilation? Are there any thinner alternatives for roofing insulation? and is it a viable option to keep joists exposed, or should I just cover them up?
Many thanks for any info you guys can provide.
