However, it must be stored above 60°C to prevent legionella.
Primary water in a heat bank ?.
Why would it need to be stored above 60 C to prevent legionella ?.
The store is there to provide instantaneous HW on demand through circulation of the stored primary water across a plate heat exchanger similar to a combination boiler !.
How effective that transfer of energy will be all depends on the sizing of the plate heat exchanger.
Might as well wade in here. The store is to store heat, not water (already pointed out I know). The water coming out of the taps at the lowest setting is 47 deg. This is in recent weeks, when the ground temperature is relatively high, and so the incoming water is not very cold. This will be very different in late November to April (approx).
As the warm (relatively) water passes through the heat exchanger, it takes heat from the store at a rate proportional to the difference between the store and the incoming temperature, and also dependant on the flow rate. If you want it cooler, you turn the tap on more. Now it is giving 47 deg when the ground water is around 15 deg, in the winter the ground water could be 5 deg, so you would be lucky to get water at 40 from the taps. Most people complain about the length of time it takes to fill a bath in the winter.
With these compromises, there is a range of temperature which will give what most find adequate. If you want something else, you have to add say, a blending valve, or you have to do what most responsible people do, and put the plug in, then mix hot with cold to get the required temperature. This saves wasting water by having the tap running all the time you are washing your hands.
There is also a zero setting, it's called the "boiler isolator switch". Turn it off and the boiler will not get any hotter than its surroundings.
Does Agile work for WB, i'm sure his previous posts stated something very similar to Martyn Bridges.
some customers are just fussy a*******s![]()
I think your being too fussy. 47 deg c is not excessively hot at all. stop moaning.![]()
P.S. Before I go to bed, one last thought.
Do me a favour M8 will you pretty please?
Get your Hot Water tap running at 47C and put your Dongler (Of which you sound like one) under it and hold it there for a half an hour.
Mr. Bridges reckons that this temperature is hot enough to clean crockery and dishes hygienically. That should do the trick for you for once.
When you get back from hospital please come and report here all about your experience.![]()
On the other hand. Perhaps that might shut you up?![]()
