Encasing old wall with cement?
19 Sep 2012
Sussex
Morning all,
I've got an old stone wall (roughly 6" wide and 10" tall) that runs the length of my garden that was originally used to create a border for a plant bed. The problem is that it's really ugly and has weeds growing through some of the stone, though the actual structure is still solid.
What I want to do is put some timber either side of the wall (about an inch or 2 away from both sides) to act as a barrier, so that I can pour cement straight over the wall and basically encasing it and hopefully achieving a smoother finish...
Is this doomed from the start or should I be using cement + some other substance?
I don't want to use conrete as I don't really want little stones visible from the sides once it's all dry.
Any advice?
you should really consider rendering it instead. Preparation is the key. The wall needs to be clean and free from green materials and dust.
That sounds ok, just leave enough concrete each side so it will have strength, as the old wall will move? You will have to use concrete for strength, the finish or lack off, will depend on the level of finish on the inside of the timber casing. You can always get it plastered afterwards.
A 2 inch thick face of concrete like that will crack even if you could get it to bond to the wall which i doubt without lots of steel ties.
Thanks for the replies.
So what about mixing the cement with some sand?
I really dont want to render the wall as it has a jagged surface.
Try a small section first. Wrap a piece of chicken wire over the wall. Add your wooden sides and then fill with a mixture of four parts (by volume) of sharp sand to one part of cement mixed to a not too dry - not too wet consistency. Leave it a couple of days and see how it turns out. It's only a garden wall!
I'd rather have a charming old stone wall than a monolithic chunk of concrete like a motorway bridge. Just grow ivy up it.
