electric oven and hob plug- hard wire
Not sure whether the Volex is dual or not.
I am a bit concerned about the one on ebay as it looks quite long and OP's outlet does not appear to be a flush fitting.
I've just realised that the dual outlet plate is too bug for the space in the wall available. i have a cable running at the top and the gas pipe just below. So I suppose is back to wiring the oven with a cable and 13 amp plug for the cooker socket...?
I can't find the amp anywhere on the oven (I don't have the manual) but is 1925 w.
1925 is just over 8a so you will be fine to put a 13a plug on it, but as already stated, you will need to put a smaller cable on the cooker
and TTC is correct, not a dual plate I linked to, misread the page, sorry
You can put all the wires in the existing connection plate although you may have to 'adjust' the cable restraint.
I'm sure I've seen a 1 gang (size) square dual connector but I can't find it on the net.
If I can really do this it would be the easiest by far. Are there any risks to this?
I wouldn't have thought that connecting the oven to the outlet plate with the hob would be a good idea.
40 amp protective device protecting a cable that looks at most 4mm
I believed all single ovens were designed for plug and socket outlet.
I would have thought wiring into a plug or changing the socket for a 13amp fused spur with a flex outlet would be the safest.
I would also make sure that your switch marked 'ignition' (for the old gas hob) hasn't got a fuse in it. If it has, you may need to change it for a 13amp.
Then obviously relabel as 'oven'
My hob ignition is fused above the counter at 5amps
Yes, quite right if it is 4mm².
It may be alright (re. no overload) but don't like advising so on the forum.
Use 6mm².
The oven cable is about 1 cm thick (10mm). The three cables inside are 5mm each.
Cable sizes are gives as cross sectional area of the conductor. So you'd need a micrometer and some maths to work out what the csa of the conductor really is.
Often it is written on the cable itself.
I have the micrometer (15 mm) but don't have the math. Back to the 13 amp for now. I'll graduate next time...
