I have no experience with boiler, I touched the flue duct on the top of the boiler,
it hurt, very very hot, I think it's over 100 Celsius (°C), is this normal?
also the top of the boiler is quiet hot, I guess it's over 65 Celsius (°C).
I stopped the boiler now...
the problem history: two week ago:
1. my boiler had a problem when I had a shower, hot water stopped, flashing quickly, I reset it working again.
2. the next day reset sometime working sometime not, asked a plumber checked, he had no confidence, said: might be PCB, but he said I might pay for nothing, so we stuck there
3, After 2 days, the boiler stop working completely, no CH no HW, flash every second, reset no help. the fuse broken, replaced still broke again, at last I found: the overheating melted 2 wires(red one green one)which are for overheat thermostat and water pressure switch and air pressure switch, I fix the broken wires, then the fuse no longer broke, but boiler still not working
4. replaced a PCB, flashing quickly, checked fan is working, short the air pressure switch, then I can hear spark, but no ignite, not working, linked out the water pressure switch, WOW, Ignite! fire up,
5. I am trying to check if the boiler is overheating or not...
